1957 Evinrude Fastwin 18hp Carb Problems after rebuild
cesarp35
Re: 1957 Evinrude Fastwin 18hp Carb Problems after rebuild
Postby cesarp35 » Tue Mar 13, 2018 8:11 pm
Hey guys ,i wanted to share this picture of the motor that i'm working on, it's really clean inside and out, just wish i had it running already!!! Parts should be here by Thursday or Friday at the latest, will post after i install them!!,
1957evinrude
Postby 1957evinrude » Tue Mar 13, 2018 8:13 pm
[size=150]That's a good looking fastwin you have there!! My favorite model year. They are good motors and have lots of power.
[/size]I was trying to enlarge the photo but was not able to.
1957evinrude
reivertom
Postby reivertom » Tue Mar 13, 2018 9:55 pm
Sometimes a motor that old is in pristine condition because it had a problem people weren't experienced enough or able to fix and didn't want to spend any more money on an old motor. They get shoved into a basement corner and forgotten about until time to clean out the house. I have a '55 Johnson 10hp in great condition that had a hard to find problem, and it took me a while to figure it out. To me, that's part of the fun.....figuring out what others gave up on.
cesarp35
Postby cesarp35 » Tue Mar 13, 2018 10:25 pm
1957evinrude wrote:[size=150]That's a good looking fastwin you have there!! My favorite model year. They are good motors and have lots of power.
Sorry i'm not to computer literate and i don't even know how that damn little heart got in the picture. LOL
cesarp35
Postby cesarp35 » Tue Mar 13, 2018 10:26 pm
reivertom wrote:Sometimes a motor that old is in pristine condition because it had a problem people weren't experienced enough or able to fix and didn't want to spend any more money on an old motor. They get shoved into a basement corner and forgotten about until time to clean out the house. I have a '55 Johnson 10hp in great condition that had a hard to find problem, and it took me a while to figure it out. To me, that's part of the fun.....figuring out what others gave up on.
Well said reivertom!!!
chris
Postby chris » Wed Mar 14, 2018 4:53 pm
Browsing through 3 pages, it doesn't look like you solved the carb issue.
I've had this exact issue on a couple '50's motors. Turned out to be the "O" ring between the upper and lower carb halves. Riser pipe I think I've heard some call it? I actually had one fail at the far end of a very long lake. Ended up making one from a section of fuel hose to get by.
Anyway, I know you've taken it apart already, but is there a chance you forgot to put it in in the first place? Maybe missing from the kit?
1955 10hp, 25hp, 1957 18hp Johnsons. 1958 35hp, 1972 50hp Evinrudes. Among others...
cesarp35
Postby cesarp35 » Thu Mar 15, 2018 3:32 am
chris wrote:Browsing through 3 pages, it doesn't look like you solved the carb issue.
Hey Chris, if you're referring to the float chamber to carb body boss gasket witch is the thick o ring thick gasket that sits on top of the high speed nozzle in the middle of the lower half of carb, i did put that on. I made a few adjustments to the float, i'm now waiting for the tune up and ignition parts to come in tomorrow. Once i install all the parts i will give it another go and post the results, i also change the pressure tank gasket and hoses
1957evinrude
Postby 1957evinrude » Thu Mar 15, 2018 6:47 am
If you can send us a video of it running !!!!! :)
1957evinrude
cesarp35
Postby cesarp35 » Thu Mar 15, 2018 10:57 am
1957evinrude wrote:If you can send us a video of it running !!!!! :)
I definitely will!
chris
Postby chris » Thu Mar 15, 2018 1:48 pm
I've also seen a main gasket (that goes between the 2 halves of the carb body) get swollen. Some would suggest that being from the Non-ethanol free gas. The gasket swelled up and was preventing the float from going all the way up, and would flood.
Users browsing this forum: Google [Bot], searay and 5 guests
cron
