Home Forum Ask A Member 1956 Johnson 10HO QD 19 exhaust housing temp Re: 1956 Johnson 10HO QD 19 exhaust housing temp
#60310
    Holy Schmokes! Not supposed to get that hot!
    Time to pull off the powerhead. In fact, I see a lot of corrosion and overheating signs. I would pull all of the covers (bypass/head/exhaust) clean, dress, install new gaskets and ensure passages are clear. Something is going on in the leg though, and you wont be able to properly fix without pulling powerhead off.
