Re: Martin 40 tank seal
Home › Forum › Ask A Member › Martin 40 tank seal › Re: Martin 40 tank seal
June 18, 2017 at 1:31 pm
#59870
The 2 piece cork gasket set from Larson is the way to go.
While it does take a little careful work to get the two piece tank apart, it does give you a great
opportunity to get the inside of the tank spotlessly clean
Larson recommends a light coat of spray on gasket sealer on the gasket upon reassembly
and you’ll be good for another 60 years.
(The 2 piece gasket is for the 40/45s and the 3 piece is for the 20)
If you are serious about not wanting your tank to leak, the $35.00 for the set is money well spent.
Respectfully,
