Home › Forum › Ask A Member › 6r74 exhaust cavity drain holes ? › Re: 6r74 exhaust cavity drain holes ?
November 29, 2017 at 4:27 pm
#68071
my 9.5 9622a has that shift handle slop… i’ll check it out closer because the (cracked ?) part is more accessible
yep this little 6hp is so clean I was surprised the pull cord had wear enough for concern. I just replaced it
i’ll be closing it up when the impeller and ph base gasket come in tomorrow , seals look ok
pleased pink with my purchase.
