Mark 25 steering
Cheetahgod
Mark 25 steering
Postby Cheetahgod » Wed Jul 12, 2017 9:02 pm
Does the mark 25 have cable string steering or hydrolic? Does anyone have a picture of how the steering connects
Re: Mark 25 steering
Postby Dave Bernard » Wed Jul 12, 2017 10:40 pm
there is a hoop part that bolts to the motor in the front look for the 2 holes one on each side. I may have one if you need. getting hard to find. cable and pulley or push pull will work on it.
kirkp
Postby kirkp » Fri Jul 14, 2017 11:16 am
They show up on ebay once in awhile, probably more often than the Mk20. The steering swivel to connect the cables to the hoop don't show up hardly ever. Only seen one. A inventive person could probably figure out a work around
steering swivel assy.jpg (215.45 KiB) Viewed 611 times
Cheetahgod
Postby Cheetahgod » Fri Jul 14, 2017 5:44 pm
Do you know where I could get that attachment?
Picture of my mk25
Postby Dave Bernard » Fri Jul 14, 2017 6:36 pm
what kind of boat are you going to use it on?
Cheetahgod
Postby Cheetahgod » Fri Jul 14, 2017 7:00 pm
boat
Postby Dave Bernard » Fri Jul 14, 2017 8:42 pm
with that boat they used a rear bar on the race motor. would need to be made custom for yours.
1 914 310 7086.
kirkp
Postby kirkp » Fri Jul 14, 2017 10:33 pm
Dave's correct. Too bad that it's not interchangeable with a Mark 20, have a bar with your name all over it.
Kirk
Postby Dave Bernard » Sat Jul 15, 2017 4:50 pm
I may have a wizard rear handle that can be put on the mark25 and a steering bar then mounted.
Cheetahgod
Postby Cheetahgod » Sat Jul 15, 2017 5:06 pm
I have a mark 20. But would prefer to put the mk25 on my boat.
Users browsing this forum: JimmY and 13 guests
