Koban Battery Ignition Commutator
sputnik16335
Postby sputnik16335 » Wed Aug 09, 2017 4:21 pm
Hi all-
I'm not sure I was successful posting this a day or two ago. Apologies if this is a duplicate.
I also posted this on another forum but I thought I'd try it here also.
I'm trying to ready my 1915 battery-ignition Koban for a test run. I still haven't found a correct flywheel, but I did find a very close substitute at a local steam-and-gas engine show. It's an iron open flywheel 13 inches in diameter, and has a hub big enough to machine it to fit the Koban crankshaft. I think it will do until I can find a correct one, or a reproduction.
The problem is that I will still need to produce a commutator ring to fit to the flywheel. I think it should be similar to one I made for an upright Maytag, but I still need to know how it is attached to the flywheel.
Any advice, pictures, etc. would be greatly appreciated.
Thanks,
Rich Roberts
76-J
Re: Koban Battery Ignition Commutator
Postby 76-J » Wed Aug 09, 2017 5:56 pm
Something " Period Correct" would be a pair of Buzz coils ( Model T Ford / or "other" )...could be made to work. I wrote "pair", based on a wild guess that your KOBAN is a 2 cylinder that are opposed ! Gas Engine guys Rock ! Good Luck ! !
76-J
Postby 76-J » Thu Aug 10, 2017 6:31 am
76-J wrote:Something " Period Correct" would be a pair of Buzz coils ( Model T Ford / or "other" )...could be made to work. I wrote "pair", based on a wild guess that your KOBAN is a 2 cylinder that are opposed ! Gas Engine guys Rock ! Good Luck ! !
OR, once your commutator has been fabbed... acquire a coil from a battery ignition ELTO ie ruddertwin , etc
Postby Tubs » Thu Aug 10, 2017 10:51 am
sputnik16335
Postby sputnik16335 » Fri Aug 11, 2017 7:01 pm
Thanks for the responses. I've sent out a note to Jack.
I have a buzz coil. Not a 'T' coil, but it easily fires the plug. I plan on making an oak box to contain it and a battery. Wiring's all ready to go.
This has been a 5 year project. Most of the time spent scrounging parts. Absolutely not because I have 'way too many projects and a short attention span (ooh look, something shiny)...
-RR
Tom Manley
Postby Tom Manley » Fri Aug 11, 2017 9:43 pm
You'll need a coil with two high tension leads, or two more typical buzz coils. Since the ground on a typical buzz coil is also one of the point leads, you can't use one of those to fire two plugs.
Tom
sputnik16335
Postby sputnik16335 » Sat Aug 12, 2017 9:23 am
I guess I was thinking four stroke. I was thinking a single coil would do it. I have a '60s Triumph where both plugs fire at the same time. One is firing into the exhausting cylinder, so it does nothing. That wouldn't be the case with two stroke two cylinder motors. I have a couple of Model T coils. Have to rethink the wiring...
Postby Tubs » Sat Aug 12, 2017 9:45 am
.Does your Triumph coil have a plug wire for both cylinders.
That is what the old Harleys had.
Can you fire 2 plugs with the buzz coil you have?
That is what Tom is trying to make to make you aware of.
Postby Garry in Tampa » Sat Aug 12, 2017 10:46 am
You can make your own with a 6 volt double pole double throw relay and a Light Four/Zephyr coil. It may need a small capacitor to protect the contacts. . . ;)
kees
Postby kees » Sun Aug 13, 2017 6:18 pm
sputnik16335 wrote:Hi all-
Thanks,
Rich Roberts
If you don't have an original flywheel then.......
this is what you need on your substitute :o
AT LEAST, THIS MUST BE THE ANSWER ON YOUR QUESTION,
I HOPE / THINK
btw. you need the original timer lever as well of course,
or you have to adapt a similar one from another rowboat motor
see attached picture
koban flywheel.jpg (4.31 MiB) Viewed 582 times
Users browsing this forum: Bing [Bot], Bullie, oldelto and 6 guests
