Alumacraft boat plug
opposedtwin
Postby opposedtwin » Thu Aug 10, 2017 9:01 pm
This is the drain on my alumacraft super C. It is unlike any other alumacraft drain i have. Anybody know the correct diameter? It looks like a finer thread pitch as well as being a smaller diameter than the other alumacraft ones i've seen.
"darkness has a hunger that's insatiable, and lightness has a call that's hard to hear"
westwind
Re: Alumacraft boat plug
Postby westwind » Sat Aug 12, 2017 9:14 am
My Alumacrafts have a smooth hole with a rubber bung, not threaded. Yours may have been owner modified at some point.
Great Northern Chapter Member
Dave Bernard
Postby Dave Bernard » Sat Aug 12, 2017 9:19 am
looks like my Durotech S13uses a plug with straight threads and a rubber washer. if you need pics I can take them latter.
XR55
Postby XR55 » Sat Aug 12, 2017 10:01 am
It may be the same as a Feather Craft plug that used British standard threads.
bill_loveland
Postby bill_loveland » Sat Aug 12, 2017 12:01 pm
My Super CS has the same thing - I'll take a look at the plug tonight.
And I'll bet my Deep C has it as well.
opposedtwin
Postby opposedtwin » Sat Aug 12, 2017 6:31 pm
Thanks for the info guys! Here's a picture of the bottom of the drain. Kinda cool. I discovered it's 5/8 fine thread. Hardware stores (so far) only have 5/8 coarse. I'll keep looking. Going to have to be short too, to fit inside the drain assembly.
westwind
Postby westwind » Sat Aug 12, 2017 6:42 pm
Maybe an autoparts store or junk yard? Looks like an oil pan drain plug would work.
http://www.ebay.com/itm/Dorman-090-024- ... 2503787500
Dave Bernard
Postby Dave Bernard » Sat Aug 12, 2017 7:24 pm
IF you cant find a short one put a nut on then a rubber washer to shorten it up. you now have a handle. mine is a wing nut type.
Mini Motors
Postby Mini Motors » Sat Aug 12, 2017 10:59 pm
You could shave down a wine cork in to a cone shape, twist it in and done. Good excuse to kill a bottle of wine.
Not that you need an excuse. Just sayin'.
jpatti75
Postby jpatti75 » Sun Aug 13, 2017 7:26 am
The shipping will cost you more than the bolt, but Bolt Depot carries 5/18-18 in various styles and grades of bolt, if you can't find it locally:
https://www.boltdepot.com/Catalog.aspx? ... wAodBfoCgw
JP
Chesapeake Chapter
Users browsing this forum: bck1 and 8 guests
