Home › Forum › Ask A Member › 1936 K-80 › Re: 1936 K-80
February 13, 2018 at 10:41 pm
#71006
SquierKA39 – Thanks for the tip about the instructions that go on the tank… I’ll have to get a set of those.
need2fish – The float pin is raised and I can push it down until fuel drips from the overflow pipe so I think I’m good there. I’ve also wondered about the coils breaking down – is there a good test? I didn’t check for spark while the motor was still warm the one time I had it going a little. Will try that again this weekend. Should be fairly straight forward to pull the powerhead and check for carbon build up.
Thanks to both of you for the tips, I’ll report back with my findings after I get a chance to work on her.
