Home › Forum › Ask A Member › If I have a wiring error, I simply can’t find it…UPDATE: FIXED! › Re: If I have a wiring error, I simply can’t find it…
February 14, 2018 at 1:20 am
#71016
Outlandish idea….Being an EE, you probably have switches lying around from Lord only knows what. You aren’t using some kind of application-specific switch with a diode buried in it, are you? One that off is open and on is closed in one direction flow only? I always warn my son that, when the human mind doesn’t know the answer to something, it starts making stuff up. Case in point.
