Home › Forum › Ask A Member › 1963 Evinrude Sportwin Skeg Pin › Re: 1963 Evinrude Sportwin Skeg Pin
February 21, 2018 at 4:45 am
#71411
OK – that makes sense. I’ve added more photos to give a better notion of the parts I’m working with. Closer inspection on the front bushing shows it’s moved around a bit on that pin as there are multiple odd spaced dimples around it where the pin landed at various times – I’m guessing the pin sheared it off at some point. Drilling it out and getting a replacement that sits higher looks to be the answer. Thanks for the advice.
