1934 Johnson A-70
10717
1934 Johnson A-70
Postby 10717 » Thu Aug 24, 2017 9:57 pm
I have been working on cleaning up an A-70 to use on a Thompson car topper. I started it tonight for the first time and it ran very nicely. Alternate firing and underwater exhaust are big improvements over the 1924 A that was my last project! But how do you tell whether the cooling system that relies on the prop is working? It seemed to heat up more quickly than I expected. Thanks.
XR55
Re: 1934 Johnson A-70
Postby XR55 » Fri Aug 25, 2017 8:18 am
This motor is a vacuum/pressure cooling system. When starting motor on boat you must go to max. engine speed to purge air from the cooling system. The motor will not cool in a tank or barrel. Touching the side of cylinder case on the opposite side from the muffler should be warm but not hot.
10717
Postby 10717 » Fri Aug 25, 2017 8:34 am
Thanks. I had it in a barrel but was reluctant to put it on the boat in a lake until I knew it was cooling. Guess I had it backwards.
10717
Postby 10717 » Mon Sep 11, 2017 9:44 am
Had it on a boat yesterday. As you said, the muffler side is hot but the spark plug side stays pretty cool by comparison. I have a short video of it running which I would be happy to share. Thanks again.
Users browsing this forum: JimmY and 12 guests
