OMC single hose tank question
Re: OMC single hose tank question
Postby FrankR » Thu Sep 07, 2017 2:44 pm
If the o-ring around the pin leaks, you can usually hear or see it while pumping the bulb. Usually.
Postby outbdnut2 » Thu Sep 07, 2017 7:18 pm
Adam1961 wrote: It seems that the valves on my tank are working as they should, as I get pressure or vacuum in the tank when moved to a warm or cold space with the cap shut.
With the cap shut and the fuel line plugged into the tank, you should not get a vacuum - the one-way vent should prevent that, but if you are talking about getting a vacuum when the gas line is not connected to the tank - yes, that's right.
Users browsing this forum: Bing [Bot] and 9 guests
