Elto Prop Depth
Slim60
Elto Prop Depth
Postby Slim60 » Fri Sep 08, 2017 10:07 pm
I took my hollow rudder Elto out on the lake on a jack plate. It ran great for 100 yards then slowed to a stop. Cylinders were very warm so I shut off the fuel and rowed back. After it was loaded onto trailer it started fine. What depth would be best for cooling? Prop level with boat bottom? Jack plate can be moved up.
Prop Depth.JPG (2.08 MiB) Viewed 242 times
Re: Elto Prop Depth
Postby Tubs » Fri Sep 08, 2017 11:19 pm
You must go to full speed after the
motor starts to get the water to start
circulating. If there are any leaks in the
system water wont circulate. Check to
see that all the fittings are tight and that
none of solder joints have failed. Did you
notice if water was coming out of the coiled
tubes when it was running?
Image Image Image Image
Slim60
Re: Elto Prop Depth
Postby Slim60 » Fri Sep 08, 2017 11:50 pm
When I bent over the stern the coils went under water. Mostly I sat in the middle seat and steered with the rope. I'll remember to run it fast at first to start the siphon next time. Meanwhile I'll check for leaks. Thanks Tubs.
Users browsing this forum: h20lew and 4 guests
