1958 Evinrude 35 HP Big Twin
rvdriver
Postby rvdriver » Mon Sep 11, 2017 10:24 am
I am searching for a couple of woodruff keys for my flywheel. I sheared one off yesterday.
Serial number is 2503408518.
I am also looking for the plastic adjustment screw for the throttle adjustment.
Thanks for the help!
Steven
Lake Granbury, TX.
Re: 1958 Evinrude 35 HP Big Twin
Postby outbdnut2 » Mon Sep 11, 2017 1:48 pm
I made a woodruff key like that - I found a piece of scrap metal the right thickness, cut it as a rectangle close to size with a hack saw, then held it with a pliers to a bench grinder until I had shaped it into a curve on one side - it worked great. Note that key is mainly for assembly, once the nut is tightened properly, with zero lube on the tapered shaft, there is little or no stress on the key. This was for a motor like yours.
If you want to buy one, go to marineengine .com.
This link will take you to it:
http://www.marineengine.com/newparts/part_details.php?pnum=OMC0302602
rvdriver
Postby rvdriver » Mon Sep 11, 2017 2:42 pm
Think you very much!
rvdriver
Postby rvdriver » Mon Sep 11, 2017 2:55 pm
Do you the flywheel nut torque?
rvdriver
Postby rvdriver » Mon Sep 11, 2017 4:28 pm
Sorry, do you know what the torque is on the flywheel nut ?
Postby Chris_P » Mon Sep 11, 2017 6:46 pm
60 to 65 ft/lbs.
I personally prefer OEM keys. Seen trouble with hardware store ones for whatever reason. They are cheap enough, I buy them in big bags.
If you need one still PM me ill send you one.
Postby outbdnut2 » Mon Sep 11, 2017 6:57 pm
In my area, no hardware store had keys that big that were that thin.
rvdriver
Postby rvdriver » Tue Sep 12, 2017 8:42 am
I ordered on from marine edge yesterday. Thanks for the great help!
Users browsing this forum: ed sam, George Emmanuel, Google [Bot] and 4 guests
