Fix for spun hub?
Jim Moffatt
Fix for spun hub?
Postby Jim Moffatt » Wed Sep 13, 2017 8:05 am
I have an Elgin 12 hp prop with a spun fubber hub. I have heard of regluing it. Does anyone have any experience with repairs that work? Could a prop shop fix it?
Re: Fix for spun hub?
Postby FrankR » Wed Sep 13, 2017 9:02 am
The normal prop shop repair is to replace the hub. But that means they need a new hub to put in it. Unlikely that they have one.
A last resort fix is to fabricate a solid hub and locktite it in there permanently. Of course that defeats the purpose of a cushioned hub.
SquierKA39
Postby SquierKA39 » Wed Sep 13, 2017 9:55 am
I have used JB weld epoxy to glue the hub on an Evinrude 15hp. That was more than 10 years ago and it's still holding.
Postby amuller » Wed Sep 13, 2017 10:39 am
Does anyone know that the dimensions are supposed to be for rubber hubs? How much of an interference fit? How hard the rubber is supposed to be? Etc...
Jeff Register
Postby Jeff Register » Wed Sep 13, 2017 3:38 pm
Can pin it from either side with roll pins.
Chinewalker
Postby Chinewalker » Wed Sep 13, 2017 5:06 pm
Start with taking it to a prop shop. Worst they can say is they can't fix it. Heading into the offseason, they may want the challenge as their business slows down.
EvilTwin
Postby EvilTwin » Wed Sep 13, 2017 8:29 pm
I wonder if 3M 5200 would work. Or Window Urethane. The urethane is tough stuff.
reivertom
Postby reivertom » Thu Sep 14, 2017 11:08 pm
I saw some liquid rubber advertised on TV the other day and wondered if it could be used for spun hubs. The commercial is cheezy but It looks like it cures really tough but pliable.
Randy in Tampa
Postby Randy in Tampa » Fri Sep 15, 2017 6:11 am
Hmmmm,time to experiment,great idea Tom ...might work on other applications ;)
reivertom wrote:I saw some liquid rubber advertised on TV the other day and wondered if it could be used for spun hubs. The commercial is cheezy but It looks like it cures really tough but pliable.
Rotary Valve Johnson's Rule 8-)
Postby Fisherman6 » Fri Sep 15, 2017 9:41 am
A somewhat different application, but I have used castable urethane to create a new hub on a prop for a motor once. It worked well and the person I sold the motor to is still using it all summer for the second year now. It was one of those oddball 5hp Johnsons with the 6hp powerhead and the 4hp exhaust leg and lower unit. It had a ribbed / splined hub so a but different, but I'm thinking of trying it for a 10hp OMC prop to see how it works. Not a super cheap solution though.
Users browsing this forum: Buccaneer, DavidK, ed sam, George Emmanuel and 6 guests
