Re: Johnson Evinrude 9.9/15 lower unit interchange
Home › Forum › Ask A Member › Johnson Evinrude 9.9/15 lower unit interchange › Re: Johnson Evinrude 9.9/15 lower unit interchange
April 15, 2018 at 3:39 am
#74017
If you try installing an early shaft with an O ring on it thru the later double seals, you’ll know right away something isn’t right as the O ring doesn’t want to fit thru the small lower seal very easily. I’ve been caught on this before and it would take a big grunt to get the O ring thru the seal! If I remember correctly, the lip on the lower seal faces out, towards the water pump, to keep water and exhaust out while the lip on the larger upper seal faces in to keep crankcase pressure/vacuum where it should be.
