Eisemann 71L magneto
sbrown21
Postby sbrown21 » Thu Oct 05, 2017 3:33 pm
download/file.php?mode=view&id=11702
I need help is there any way to put a OMC coil on this Eisemann magneto. There are lamanets on the end but there is a solid round rod that connects the two ends . I think the rod is welded or pressed on to the lamanets. I took it apart thinking that the center would be square and the same as the ends. Should I put a fork in it and say I'm done or is there a way to salvage this coil ? Eisemann 71L magneto
Re: Eisemann 71L magneto
Postby Richard A. White » Thu Oct 05, 2017 4:05 pm
Sure is, there is a writeup in one of the older Outboarders....I helped with the article but it was written by Jim Moffatt
George Emmanuel
Treasurer AOMCI
Postby George Emmanuel » Thu Oct 05, 2017 7:58 pm
You cannot machine a part like that if it has laminates on the ends and a solid in the middle, so obviously, it should come apart. I haven't done one of those but I've modified several other types. See if that round bar will come out by tapping the laminate away from the bar. Go gently. I think those brass grommets are there to hold the laminates together and should not be part of the round rod.
George
sbrown21
Postby sbrown21 » Thu Oct 05, 2017 10:20 pm
Thanks, the laminates run all the way through the rod witch is not one piece but laminated too. I drove the brass grommets out and gently separated the lamanets there were 2 pins holding the bar together. Now can I put the square hole on the OMC coil on the round lamantes on this coil with out making square? I will send a picture of the lamanets. Thanks Richard White and George Emmanuel
Postby Richard A. White » Fri Oct 06, 2017 6:08 am
Each laminate is modified differently, I performed this exact procedure on the same coil heel.... Let me find the info this evening and I will post the Outboarder is from between 2007 and 2009 detailed pics are in there. My Neptune Mastertwin was the motor I did this conversion on, and save a bd upper crankshaft seal the motor runs well
Phil B
Postby Phil B » Sat Oct 07, 2017 4:50 pm
The thing I remember seeing in articles was to cut half the laminates in one place, and half in a different place, so you can reassemble them with the joints alternating. Using ][ to show where the laminations have been cut:
Code: Select all
Assuming the new coil leaves enough space on either side to run a bolt thru to keep the stack together.
Putting the widest (old center) laminations on the outside of the stack might give you a square enough profile to hold a coil that has a square hole....
sbrown21
Postby sbrown21 » Sat Oct 07, 2017 8:47 pm
I have put the OMS coil on the Eisemann heels I cut the lammanets in two different places to stagger the cuts and reattached them. Do you think that I will have to change the condenser or use the old 71L eisemann condenser ? I have squared up the lammanets and put it on the motor. I will have to add some more wire from the condenser to the coil but think it will work. any suggestions posted pictures below.
Postby Richard A. White » Sun Oct 08, 2017 7:55 am
Ok, the problem is those cuts need to fall in a location that has them inside the coil, if that makes sense, here are my photos of when I did this. I USED 2 OMC coils on this laminate for my Neptune Mastertwin
laminations and old rivets 1.jpg (60.7 KiB) Viewed 526 times
IMG_0496a 1.JPG (56.72 KiB) Viewed 526 times
IMG_0497a 2.JPG (41.6 KiB) Viewed 526 times
Last edited by Richard A. White on Mon Oct 09, 2017 1:36 pm, edited 2 times in total.
49Hiawatha
Postby 49Hiawatha » Mon Oct 09, 2017 12:47 pm
Nice show and tell. Thank you.
Postby FrankR » Mon Oct 09, 2017 1:39 pm
Richard, I assume that worked for you, but I'm surprised that it did. I'll have to get out my old textbook on transformers and read up on the subject.
Users browsing this forum: ed sam, flyingvranch, PugetSoundBoater, Royal1954 and 8 guests
