1972 85 hp V4 reverse latch rod?
Postby amuller » Mon Oct 09, 2017 1:44 pm
This seems like a question I shouldn't need to be asking, but simple as it seems I can't figure it out....
There is a rotating lever that pulls on a rod. That part is fine. But what does the bottom of the rod connect to? There is a hole in the latch. There is a 90 deg bend in the bottom of the rod. But there is nothing to keep the rod in the hole and I don't see any wear patterns. What does this rod connect to?
I am having little luck with pics this morning. Hope this one is viewable.
Re: 1972 85 hp V4 reverse latch rod?
Postby fleetwin » Mon Oct 09, 2017 2:40 pm
Yes, viewable...
http://www.marineengine.com/parts/johns ... st+Housing
Usually, the rod #37 wraps around the pin #47, but clearly that is not the case here....Hopefully someone has a similar model they can peek at for you....
Postby amuller » Mon Oct 09, 2017 3:17 pm
I've studied the hell out of that illustration. The rod is too short to hook around the pin, even it it had a loop rather than just a bend. It does seem to be the right length to engage the hole in the "locking lever" but there is nothing to hold it in place. Puzzling....
Postby Garry in Tampa » Mon Oct 09, 2017 3:50 pm
How about if you turn it 180 degrees and come in from the other side ?
Postby amuller » Mon Oct 09, 2017 5:51 pm
Garry in Tampa wrote:How about if you turn it 180 degrees and come in from the other side ?
IBecause of the way the rod is curved at the top to allow overcenter action it probably could not be done.
What I did was strap the rod in the hole with lockwire. Not an ideal solution but this project has to go together.
I still think there is something missing here--either an insight or a part.
Alan
Postby FrankR » Mon Oct 09, 2017 6:16 pm
I seem to remember it simply goes through the hole and stays there. But this seems to dispute that. I suspect you don't have it installed correctly at the top, making it point the wrong way at the bottom. Again, it "seems" like it is supposed to point fore or aft, whichever the case may be. But how to remember after 50 years?
Postby amuller » Mon Oct 09, 2017 8:05 pm
I got this response on iboats, agreeing with Frank above:
"It simply goes in the hole of the lift bracket... impossible for it to come out unless the rod is bent/tilted quite a ways."
It has a curve to it and points at about a 45 deg angle from fore-and-aft. The lock/unlock lever also seems quite loose.
I guess I understand it now.
Thanks.
Users browsing this forum: Google [Bot] and 11 guests
