Scott Atwater 5hp Seals
James Davis
Postby James Davis » Wed Oct 11, 2017 8:48 pm
rebuilding scott 5hp, the crank seals on bottom end look like two , one lip facing inside, one out. my parts manual shows nothing on bottom, just top. any one know? seals are falling apart, any numbers would help, none on metal rings. Thanks Jim in Florida
Jeff Register
Re: Scott Atwater 5hp Seals
Postby Jeff Register » Wed Oct 11, 2017 10:07 pm
Check, crank lateral play, bad bearings wallow seals out. What vintage?
Postby FrankR » Wed Oct 11, 2017 10:20 pm
Don't know what model you have, but my 3745 has seals top and bottom. TCM part numbers and sizes are noted on this drawing
James Davis
Postby James Davis » Thu Oct 12, 2017 10:02 pm
about a 1953, I haven't checked numbers, bailer , drawing shows two seal like mine, anyone know facing. seals looked good, just dry rotted.end play seems okay. this motor hasn't run in twenty years since it set up. guy I got it from said he was Atwater's nephew. not sure about that.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 6 guests
