Nice TN27 $50 - winter project
Re: Nice TN27 $50 - winter project
Postby crosbyman » Sun Nov 12, 2017 9:24 am
Thanks copied everytyhing ! ... parts prices are good :)
Seakaye12
Postby Seakaye12 » Sun Nov 12, 2017 10:32 am
I always enjoy those parts lists that come with prices! To think that prices were considered stable enough to do that. The universal magneto coil was $7.50.....quite a bit considering how long ago that was.
hag
Postby hag » Sun Nov 12, 2017 9:21 pm
Well, more serious then I thought. The head bolts are not missing, they are broken off. Yup 5 of them, not sure I can dig out all of them!
I’ll try Doug Penn to see if he has crankcase, but any other suggestions?
Postby crosbyman » Sun Nov 12, 2017 10:31 pm
depends how much you want to spend in light of what you found. 5 broken bolts ....hum ...time to fold
Postby Jerry Ahrens » Mon Nov 13, 2017 8:20 am
Before you put much work into it, I would suggest doing a compression check. If I remember correctly, around 75 psi and up is good. 85 is better. Compression under 70, and you will have a hard starting motor, as well as one that won't idle down.
I v'e only found one TN with a good powerhead over the years, and many that are worn out... due to high hours, or running them 50/1.
Users browsing this forum: crosbyman and 4 guests
