Coils for Mercury KG-4
marlod
VP Publications AOMCI
Postby marlod » Tue Nov 07, 2017 8:55 pm
I am looking for 2 coils for a Mercury KG-4. Can anyone help me out or give me info as to where I can purchase them?
kirkp
Re: Coils for Mercury KG-4
Postby kirkp » Tue Nov 07, 2017 10:11 pm
I've bought several coils from Jim.
Kirk
viewtopic.php?f=3&t=13895&p=72849&hilit=scintilla#p72849
chuckw
Postby chuckw » Wed Nov 08, 2017 6:41 am
Jim nol longer has phelon coils. I recently asked him.
mercuryman
Postby mercuryman » Wed Nov 08, 2017 7:09 am
Standard S3 604 at RockAuto will fit . Its not too hard to convert to OMC coil. Out of stock at Rockauto but Amazon has them fro $34.95
Mercury -MK20, MK10, KH7, KG7,KG4, KE4,KE4, KE7, KF5,KF3,KE3,KD4
Wizard WH7, WD4
Sea King 5, K1 (merc)
Bendix SMD , Champion 4.2 , Scott 7.5,
ddwilson
Postby ddwilson » Fri Nov 10, 2017 8:29 pm
[Might check with Joe Poole at Ferguson Poole he is a good source for mercury parts
Doug
Member MOB Chapter
1930 Johnson A50
1932 Johnson K50
1951 Wizard WG7
1953 Wizard WH7
1958 Johnson QD19
1959 Johnson CD16
and the list goes on........
Postby Tubs » Fri Nov 10, 2017 10:35 pm
I'm in the process of putting some
OMC coils in a Marl-7.
I've gotten this far.
https://youtu.be/fWfob_qnUcs
mercuryman
Postby mercuryman » Sat Nov 11, 2017 7:08 am
I have installed the OMC coils on Phelon cores they work good but the wire routeing is tight. I don't see how you can beat the Amazon price for S3-604 coil.
Wizard WH7, WD4
kirkp
Postby kirkp » Sat Nov 11, 2017 10:52 am
mercuryman wrote:Standard S3 604 at RockAuto will fit . Its not too hard to convert to OMC coil. Out of stock at Rockauto but Amazon has them fro $34.95
I see the amazon dealer only has one left. Ebay has them for $41+. Summit racing has them for $35
https://www.summitracing.com/parts/smp- ... gK0W_D_BwE
Kirk
MikeSea7
Postby MikeSea7 » Sat Nov 11, 2017 11:22 am
Go to my post one section of posts back in #2
KG4 Coils More updates in last reply 11.02.2017 'Updated Removal'
I did all the homework.
Mike
Do it like you mean it Or......Don't bother. ;)
Postby Tubs » Sat Nov 11, 2017 12:06 pm
mercuryman wrote:I have installed the OMC coils on Phelon cores they work good but the wire routeing is tight. I don't see how you can beat the Amazon price for S3-604 coil.
Coils --.jpg (170.12 KiB) Viewed 689 times
Users browsing this forum: FrankR, Slimbob and 17 guests
