Solvent to put in 'stuck' motor
twostroke
Postby twostroke » Sat Nov 11, 2017 2:19 pm
Does anyone know of anything any better than Kroil to put in the cylinders of a motor that's stuck from setting?
Gotta' Chris-Craft Challenger that's stuck....and cylinders look really nice through a Snap-On camera....it's not like it's rusted solid.
Someplace on here I found a formula for some witches' brew that was acetone and some other stuff...and can't find it now.
Thanks!
Jim
Re: Solvent to put in 'stuck' motor
Postby Jerry Ahrens » Sat Nov 11, 2017 2:39 pm
50/50 acetone and ATF [trans fluid] is supposed to work well... I haven't tried it myself though.
Postby crosbyman » Sat Nov 11, 2017 3:13 pm
I have pulled the head on badly stuck 9622a 9.5 AKA "anchor" and took 2 weeks soaking and a wooden peg & hammer to slowly jar it loose
used marvel oil ... release-all etc....
it now rides along my ETEC 75hp and runs perfectly
CaptChuck
Postby CaptChuck » Sat Nov 11, 2017 3:36 pm
If the cylinders are that nice I might be suspecting a lower unit problem.
1926 ELTO Ruddertwin
1929 Evinrude Fastwin
1948 Mercury KE4
1967 Evinrude 3702C (folder)
B.Morrison
Postby B.Morrison » Sat Nov 11, 2017 9:01 pm
I've done the 50/50 acetone,atf and let it sit. Worked for me and it was stuck/rusted.
Slim60
Postby Slim60 » Sat Nov 11, 2017 10:34 pm
I keep some in a "Zoom Spout" oiler. Works great.
Postby Fisherman6 » Sun Nov 12, 2017 8:28 am
I have used the 50/50 ATF-Acetone solution and it has worked for me. I have a name for it (Pink Panther P---) because of its appearance and aroma. I have some soaking in a 16hp Elgin that's stuck hard. So far no movement on that one. I freed up a stuck QD with it and I have a couple more powerheads to try to free up and I'll use it on them too.
Postby outbdnut2 » Sun Nov 12, 2017 11:52 am
Be sure it isn't stuck somewhere else, like a broken water pump impeller vane jamming the pump, or rusted up lower gears - I've occasionally found both of these situations.
twostroke
Postby twostroke » Sun Nov 12, 2017 12:20 pm
No...pistons are stuck. I've actually got the powerhead off and on the workbench. She be stuck. I have two, so it's no big deal. One is 100% complete and unmolested (and stuck)....the other's missing some stuff but runs nicely and pumps water. I just thought that if I could free it up, I'd disassemble both and use the best internals to make one restoration, and the 'off' the left over parts.
I'll appropriate some acetone at work tomorrow, and replace the Kroil with that.
Jim
Postby crosbyman » Sun Nov 12, 2017 5:57 pm
try the peg and hammer method* .... "patience brings joy" said the fortune cookie
* short moderate blows....
Users browsing this forum: Ray Schaber and 17 guests
