K case I.D. no casting numbers
MikeSea7
Postby MikeSea7 » Sat Nov 11, 2017 7:50 pm
Hi Folk's,
Just wondering what this case is from no casting numbers?
k case 3.JPG (31.31 KiB) Viewed 420 times
k case 2.JPG (33.39 KiB) Viewed 420 times
k case 1.JPG (33.38 KiB) Viewed 420 times
Thanks,
Mike
Mike
Do it like you mean it Or......Don't bother. ;)
20mercman
Re: K case I.D. no casting numbers
Postby 20mercman » Sat Nov 11, 2017 10:43 pm
It's either a Mercury Mark 15 or 20. Most likely a Mk-20 as there were a lot more of them built. The boss on the starboard side is for mounting the linkage for the throttle/magneto. The boss on the port side is for the air pressure pump for the pressure tank.
Steve
MikeSea7
Postby MikeSea7 » Sun Nov 12, 2017 6:53 am
Hey Steve,
Thank you very much I am new to outboards and never saw this style of case.
Mike
Mike
Postby Dave Bernard » Sun Nov 12, 2017 10:57 am
I would lean more toward the Mark 20 due to the size of the carb opening.
foot_doctor
Postby foot_doctor » Sun Nov 12, 2017 11:41 am
It's pretty simple to tell the differance between the MK15 and MK20 cases. The MK20 was equipped with the larger, high speed SJ7173 roller bearing. The Mk15 used the full complement Torrington drawn-cup needle. In addition they both had the same size carb opening, but you should be able to discern the outward appearance of the MK20 case by the flat almost rectangles cast on the exterior of the bottom crank throw areas
MikeSea7
Postby MikeSea7 » Sun Nov 12, 2017 3:42 pm
Ron,
It had the 7173 bearing assembly in it.
IMG_2148 MK20.JPG (38.77 KiB) Viewed 326 times
Thanks,
Mike
Mike
Users browsing this forum: necks and 4 guests
