Aluminum gas tank dent repair
Re: Aluminum gas tank dent repair
Postby SquierKA39 » Fri Nov 17, 2017 5:27 pm
Great to hear it's a runner! Let's see a picture of it all together. What did you use for condensers, I'm going to need to replace them on my K-80 and I'm sure they are the same.
Postby Buccaneer » Fri Nov 17, 2017 6:22 pm
I used Digi-Key capacitors,
BC2609-ND, rated at .22uf.
I fitted them in the well where the
original rectangular condensers were.
Now that I know it runs, I'll look for
a decal for the gas tank.
It won't be a "show piece", but at
least it should turns some heads
out on the lake next summer with
the fisherman wondering what that
"contraption" is, lol.
P.S.- I believe I have the correct tiller handle coming.
Postby Tubs » Fri Nov 17, 2017 10:21 pm
Tank looks pretty good especially when you consider
what you had to start with. When you get to take
the motor out those who see it may think your tank
isn't much. If they only knew. Looks like you have
gotten the curve out of sides and back. Seem to be
pretty flat know. Dented tanks aren't hard to find
so we will be looking forward to your attempt.
Postby Fisherman6 » Sat Nov 18, 2017 8:18 am
That tank turned out nicely considering how smashed up it was when you started. Nice work Bucc! Great to.hear it's a runner. Looking forward to a video when decent weather returns.
Postby david bartlett » Sat Nov 18, 2017 8:45 am
I think you did great. Learned something new in the process which will likely help you(and others) later on with other motors.
Well done.
Users browsing this forum: George Emmanuel and 10 guests
