TN-27 powerhead/crankcase equivalents
hag
Postby hag » Mon Nov 13, 2017 8:25 am
Found a free free TN-27 but after getting it home and taking a good look at it i’ve Got problems. 5 broken head bolts in the crankcase. Found eBay listing for power head from “TN-20”. Thinking instead of digging the broken bolts out get a replacement crankcase or entire power head but can’t find one as of yet. (On a different topic thread I saw on the board somebody mentioned Doug penn is away?). Is there equivalent from different models like this tn20 I saw on eBay?
hag
Re: TN-27 powerhead/crankcase equivalents
Postby hag » Mon Nov 13, 2017 10:59 am
On marineengine.com model number look up it does not look like they made a TN-20 as it is listed . Probably a TD-20. Which probably less likely to be compatible.
Postby FrankR » Mon Nov 13, 2017 12:00 pm
Golly, Johnson must have made about three trainloads of TN motors. It shouldn't be hard to find what you want. I'll bet somebody here will be contacting you. You can also place a free want ad on the Webvertize classified ads pages.
First TN was a TN-25, 1950.
hag
Postby hag » Mon Nov 13, 2017 11:07 pm
Well I hope so Frank. And ya I’ll put an ad up also. And I’ll keep looking around too. I was hoping Doug Penn would right back but apparently he is away. He was able to help me with previous motors. Hope all is well.
Postby Mumbles » Tue Nov 14, 2017 10:10 am
Try tracking this guy down. I'm sure he has a donor in the mix.
TN Hoarder.jpg (114.87 KiB) Viewed 426 times
hag
Postby hag » Tue Nov 14, 2017 7:54 pm
Wow ! That’s why I can’t find a parts motor...he has them all!! :lol:
Chinewalker
Postby Chinewalker » Wed Nov 15, 2017 11:24 am
I'm in Northern NY, north of Watertown. I have several TN/TD parts motors. I can dig around and see if I have just a block...
hag
Postby hag » Thu Nov 16, 2017 2:45 pm
Thanks chinawalker I just pm you
Jeff Register
Postby Jeff Register » Thu Nov 16, 2017 4:49 pm
Had a TN-27 worn out, Cool to build one, Reminds me of Merc's have to be dialed in correctly. I'll look what I have & it's yours, Ho Ho Ho, ;)
Jeff
hag
Postby hag » Thu Nov 16, 2017 5:03 pm
Thanks Jeff pm you too
Users browsing this forum: crosbyman and 4 guests
