Home › Forum › Ask A Member › Stalling 1965 Merc 39 › Re: Stalling 1965 Merc 39
June 10, 2018 at 11:37 am
#77748
mine doing the same thing till I raised up the fuel tank and put it on the back seat next to the engine and it stopped dying
that’s how I used it after but never dug in and get around to check out the fuel pump….I moved on to a 9.5 as my troller and back up engine.
I suspect the pump was weak somehow and could not lift the gas so I am likely due to change the diaphragm
also… do check for air leaks in that silly little connector and ensure the tank vent is clean
I
