Home › Forum › Ask A Member › FD-19 Johnson hard starting › Re: FD-19 Johnson hard starting
May 29, 2018 at 5:14 pm
#76994
If you work on more than one, or have more than one OMC from between 5 hp and 20 hp, the timing tool will pay for itself it setting the timing right the first time, every time… It removes ALL doubt about firing at the right time AND firing 180 degrees apart.
classicomctools@gmail.com
