waterwitch spark plug wire soldering
keplerfan
Postby keplerfan » Mon Dec 04, 2017 3:16 pm
I have a waterwitch that had a problem with a chronic misfire. I re twisted the spark wire where it connects to the coil and the misfire stopped. I bought a new wire but I don't know the best way to attach it to the coil. should i solder it? i just dont want to damage the coil. any thoughts?
Re: waterwitch spark plug wire soldering
Postby Dave Bernard » Mon Dec 04, 2017 4:22 pm
IF you solder it , tin the coil and wire first don't need much heat for that. the assemble them and just heat till solder just melts no more. hope this helps. mercury said just twist the wire.
Jeff Register
Postby Jeff Register » Mon Dec 04, 2017 4:50 pm
Dave has it correct! Old windings are touchy to heat. Not only tin the tab but very careful not to get too hot :twisted: Tin the wire first 2, & use flux please,
Postby FrankR » Mon Dec 04, 2017 4:56 pm
Not having a clue how the wire is attached to the coil on a Waterwitch, IF it is securely twisted through a tab or something, no solder is necessary. You are dealing with high voltage here, not nearly as critical as low voltage.
Jeff Register
Postby Jeff Register » Mon Dec 04, 2017 6:54 pm
Frank is correct, save that coil,
keplerfan
Postby keplerfan » Tue Dec 05, 2017 2:13 am
can the heat blow the coil if I heat it to much? perhaps the problem was just a dirty connection?
Jeff Register
Postby Jeff Register » Tue Dec 05, 2017 10:51 am
Heat will destroy the secondary windings, Get a pic of the connection for us to see please,
keplerfan
Postby keplerfan » Tue Dec 05, 2017 11:44 am
Postby FrankR » Tue Dec 05, 2017 2:09 pm
That will be just fine as is. I don't know why it worked after you twisted it and not before. But there are thousands of motors out there with merely twisted spark plug wire connections, and no problem
BTW, what's with the tape? Maybe something hiding under that?
keplerfan
Postby keplerfan » Wed Dec 06, 2017 1:51 am
There is a small ding under the tape. I put it there to see if it was arching in that area but it is not.
Thanx for your advice, all. I will leave it twisted and test t again.
Neil
Users browsing this forum: foot_doctor and 5 guests
