1977 Evinrude 6hp losing spark
Re: 1977 Evinrude 6hp losing spark
Postby Mumbles » Wed Dec 06, 2017 10:31 am
I've had trouble with these mags before and it was caused by a broken wire where the small plate crimps the harness to the mag plate. As the mag plate advances, all the flex is in this area compounding the problem.
I don't have the manual in front of me giving the specs for the two coils but if you hook up an ohmmeter to the coils leads and slowly flex the wire harness, any jump or variation in the reading will confirm a break in the wiring. It's also a good time to confirm the coils conditions to as they can go bad.
davesko
Postby davesko » Wed Dec 06, 2017 11:54 am
Thanks Mumbles, I will look out for that. As for carb isssues others have mentioned.I do a compression and spark test before I begin any new to me motor. It had no spark at all until the throttle was turned up. The wiring looked suspect right off which is what prompted me tp turn the throttle up while spark checking. This motor is exceptionally nice so I’m probably going to just put a new driver coil and sensor in which of course has new wires rather than splicing. Thanks for all your help. Dave
Postby fleetwin » Wed Dec 06, 2017 4:08 pm
Yes, please don't attempt to "replace the wiring", could be a very expensive project that does not solve your problem. Like Rick says, you need to do some more basic concrete troubleshooting that will help pinpoint what system is causing your problem. Like everyone has said, start with basic/simple inspections. I am not yet convinced you have an ignition problem.
davesko
Postby davesko » Wed Dec 06, 2017 5:16 pm
Replaced the wiring,it was pinched like mumbles suggested. I already knew there was no spark on low throttle position before I even attempted to start the motor therefore eliminating a fuel issue. Great spark now and motor runs great. Thanks for the help. Dave
Postby fleetwin » Thu Dec 07, 2017 12:27 pm
OK, so what wiring did you replace, and what component was affected?
davesko
Postby davesko » Thu Dec 07, 2017 5:25 pm
Replaced all 4 wires. Two to the driver coil and two to the sensor with rubberized wire. When I stripped the plastic sleeve off the four wires I found two barely together. There was splices under the flywheel and I cut them there and soldered the wires and covered in heat shrink. I then loomed them together and tucked them nicely to avoid chaffing. Had it out today for about two hours and runs wonderfully. I appreciate the help. Thank you Dave
Users browsing this forum: scotty1960 and 3 guests
