Home › Forum › Ask A Member › ’57 Golden Javelin – fuel consumption question › Re: ’57 Golden Javelin – fuel consumption question
June 27, 2018 at 10:42 pm
#78569
What does the boat and motor weight? Is the motor running in top tune, what is the compression of each cyl. ? What is the top speed of the boat and what is the engine RPM at wide open throttle? What is the dia. and pitch of the prop or what is the prop mfg. prop number? This motor should not be a gas guzzler.
