Home › Forum › Ask A Member › Johnson Flywheel with a stripped puller hole › Re: Johnson Flywheel with a stripped puller hole
July 4, 2018 at 12:22 am
#78986
You can pick the OMC pullers up on Ebay, not to bad in price either. I wouldn’t be without one. The problem with the harmonic balancer puller is that it flexes to much. What makes the OMC puller work so well is the special bolts and thick washers.
