1967 Mercury 6hp thoughts
davesko
Postby davesko » Tue Jan 09, 2018 10:59 pm
Hello all, I just came across a 67 Mercury 6hp that was used one year and forgotten about. It’s in amazing condition cosmetically. I plan to take care of all the usual suspects mechanically that I do on my Omc Motors but this is my first Mercury. Any thoughts or suggestions would be appreciated. Thank you Dave
Dave Bernard
Re: 1967 Mercury 6hp thoughts
Postby Dave Bernard » Tue Jan 09, 2018 11:09 pm
Great motor. call me if you need help. worked on many of them.1 914 310 7086. Dave.
davesko
Postby davesko » Tue Jan 09, 2018 11:11 pm
Thank you Dave. Will I need any specialized tools to do the basic tune up, water pump ect?
Dave Bernard
Postby Dave Bernard » Tue Jan 09, 2018 11:15 pm
NO .straight forward 2 nuts pulls the lower unit off 2 nuts pulls the water pump apart. has points under the flywheel.
davesko
Postby davesko » Tue Jan 09, 2018 11:25 pm
Great! Thanks so much. Really looking forward to getting it going. Motor is an absolute time capsule. Amazing shape with all original paperwork. Got it from the original owner. Thanks again Dave
Dave Bernard
Postby Dave Bernard » Tue Jan 09, 2018 11:36 pm
anytime.
ddwilson
Postby ddwilson » Tue Jan 09, 2018 11:47 pm
Great running motors will idle smooth down to where you can almost count revolutions. Easy to work on too but do not have to very often very reliable
Doug
Member MOB Chapter
1930 Johnson A50
1932 Johnson K50
1951 Wizard WG7
1953 Wizard WH7
1958 Johnson QD19
1959 Johnson CD16
and the list goes on........
BillW
Postby BillW » Wed Jan 10, 2018 5:49 am
Take care to lube the pump's water tube grommet and put the lower unit back on nice and straight or the water tube can be bent. Impellers are only reliable for about two years. After that, it's a crap shoot. Really good fresh water motor. Salt water, not so much, with the steel shafts. I would check/change gear oil after every use, to keep its mint condition mint. I'm very envious of it. It sounds really nice!!
Dave Bernard
Postby Dave Bernard » Wed Jan 10, 2018 1:48 pm
Another thought, use John Deer Corn Head Grease in the lower. it is much better protects better than the oil and stays in better.
Jeff Register
Central Arizona Chapter President
Postby Jeff Register » Wed Jan 10, 2018 3:14 pm
10-4 Dave,
Compression? Check mag, fuel & crank seals,
Users browsing this forum: Chris_P, Garry in Tampa and 10 guests
