Martin 100 seal
mercuryman
Martin 100 seal
Postby mercuryman » Wed Jan 10, 2018 5:06 pm
Anyone know a SKF # for upper and lower crankshaft seal for the Martin 100. My motor hard to start and won't stay running, has real good spark.
Mercury -MK25, MK10, KH7, KG7,KG4, KE4,KE4, KF5,KF3,KE3
Wizard WH7
Sea King 5
Bendix SMD , Champion Hydro-Drive 4.2 , Scott 7.5
Re: Martin 100 seal
Postby Jerry Ahrens » Wed Jan 10, 2018 6:30 pm
I cant help with the seal numbers, but a suggestion... I would check the valves on the intake of the motor. My Martin 45 has O-rings, one on each valve, that were hardened and cracked from age. I ordered new ones from Russ Larson (Martin guy) and replaced them. My old, original O-rings leaked crank case pressure terribly when the motor was pulled over. This would be the same scenerio as leaky crankshaft seals, only worse. I believe some early Martin's had regular valves without O-rings, and some had O-rings... I'm not sure on your 100? Might be worth checking into. The other thing I found on my 45 was stuck rings. I had to remove the exaust cover,
and sprayed it liberally with Mercury Powertune. After soaking a few days, and with a little help working them with a small screwdriver, they finally freed up. That motor will idle down now, like a modern 4 stroke. BTW, be sure to reinstall the valves in the original holes that they were removed from. In other words, don't mix them up. Hope this may help!
mercuryman
Re: Martin 100 seal
Postby mercuryman » Wed Jan 10, 2018 7:08 pm
You know the Martin 100 has roller bearings on crank so it needs good seals. But I will check out the poppet valves and rings.
Wizard WH7
Sea King 5
Re: Martin 100 seal
Postby Buccaneer » Wed Jan 10, 2018 10:10 pm
Manuals to download are at
http://www.joeoutboard.com/resources/Ma ... tsList.pdf
It shows both crankcase seals for the Martin 100 as
part # 55029
mercuryman
Re: Martin 100 seal
Postby mercuryman » Thu Jan 11, 2018 3:46 pm
SKF makes oil seals and I found the SKF #. Took the power head apart and measured the old seal ( shaft .875 X OD 1.375 X W .25) This crossed to SKF 8660. Found 2 on Amazon.
Wizard WH7
Sea King 5
Users browsing this forum: Majestic-12 [Bot], PugetSoundBoater and 8 guests
cron
