way to remove Shift Rod Seal On 1957 Johnson 5.5? cd-14
Silvab7232
Postby Silvab7232 » Thu Jan 11, 2018 8:25 am
I was wondering if anybody new the best way to remove a shift rod seal on a 1957 Johnson 5.5 hp? Model # CD-14
Re: way to remove Shift Rod Seal On 1957 Johnson 5.5? cd-14
Postby david bartlett » Thu Jan 11, 2018 9:04 am
My go to tool for this is my Starrett 5/16” pin punch. If that doesn’t do it, then tap the bushing a few turns with a 5/16 tap. Screw in a bolt and tap it out by tapping on the bolt from above.
aquasonic
Postby aquasonic » Thu Jan 11, 2018 10:22 am
Frank Robb has some great information on his website: http://www.franksoutboardtools.com
Postby Mumbles » Thu Jan 11, 2018 12:22 pm
If you can turn or grind down a bar of steel to use as a punch, you'll be all set.
Shift Rod Bushing Tools.JPG (3.29 MiB) Viewed 156 times
Shift Rod Bushing Tool.JPG (3.07 MiB) Viewed 156 times
Postby Fisherman6 » Thu Jan 11, 2018 3:26 pm
This is assuming, of course, that you have the powerhead removed, shift rod disconnected, lower unit removed from the midsection, gearcase drained, skeg removed from the gearcase and all the internals out of it.
Silvab7232
Postby Silvab7232 » Thu Jan 11, 2018 8:52 pm
Yes they are all removed, Thanks!! :)
Users browsing this forum: B-Dittmar, Bing [Bot], wbeaton and 15 guests
