1948 3.3HP Evinrude Parts Diagram
Re: 1948 3.3HP Evinrude Parts Diagram
Postby Garry in Tampa » Thu Jan 18, 2018 8:57 am
A lot of people are doing that . . .
kevinrude
Postby kevinrude » Tue Jan 23, 2018 5:12 pm
Marine Engine claims to have 8 in stock:
https://www.marineengine.com/newparts/p ... OMC0170336
bookfuzz
Postby bookfuzz » Fri Jan 26, 2018 1:23 am
thanks
skanders01
Postby skanders01 » Sat Jan 27, 2018 1:31 pm
Ok, thanks for the help on this. New float acquired. Next question is what location should the float speed nuts be set to allow for proper float positions? ...or is the float to be locked in one positions
Thanks!
Kyle
Kyle Anderson
DePere, WI
920-532-6229
skanders@new.rr.com
Postby Mumbles » Sat Jan 27, 2018 8:00 pm
Speed nuts? The original cork float uses the two 120813 brass lock clips to hold it in proper position. The clips snap into small grooves on the needle to hold the float in position. When using the Merc floats, I like to drill them slightly smaller size than the needle so they are a snug fit on the needle. This way they can be adjusted up or down as required without slipping on the needle. Replacing the lower lock clip probably wouldn't be a bad idea to as it would help to prevent the float from going too far down on the needle.
skanders01
Postby skanders01 » Sun Jan 28, 2018 10:21 am
Thanks, Mumbles. What you said....lock clips. Better break out the magnifying glass again! Missed the small groove for the clip above the float. Probably didn't push it down far enough to feel the clip seat in. WIll need the magnifier anyway to search the floor for the round brass lock clip that went flying when I removed it. Looks like that is not so critical as an e-ring would work there as well.
Kyle Anderson
DePere, WI
920-532-6229
skanders@new.rr.com
Users browsing this forum: Fisherman6, jasper60103, RPSIII, Stanley, twostroke and 3 guests
