12 hp gale 1956
Adam1961
Re: 12 hp gale 1956
Postby Adam1961 » Mon Jan 15, 2018 1:30 pm
Frank,
Using the superseded numbers, I found the correct needle and seat in my inventory. It is a 5/16 and has the usual small orifice. I will measure it against the one for the remote tank motors. The only difference visible at a glance is that the needle has a groove and clip to hold it to the float arm.
I will post back when I have compared the by measuring.
need2fish
Re: 12 hp gale 1956
Postby need2fish » Mon Jan 15, 2018 3:12 pm
Frank, you just saved me a lot of trouble.... I was just about to convert my Buccaneer 12 to tank fed. I'll have to source a 12 hp pump-compatible carb.
I was going to convert my Viking 5, but it's not necessary project so I'll leave it -- the tank is quite large and the motor runs a couple of hours with it.
Adam1961
Re: 12 hp gale 1956
Postby Adam1961 » Mon Jan 15, 2018 7:23 pm
So here are my findings. As you can see in the photo, both seats have a 5/16 thread, but the one for the gravity feed motors has a larger orifice. This makes sense. It must be that the 12Hp needs even more fuel and requires the 3/8 seat when it is gravity fed.
To bring this back to the original issue, how does this all affect up pump conversions? I have not looked through parts books yet to see what was contained in the factory conversion kit, but I doubt that the seat would had been replaced, which would starve the motor of tank fed.
Re: 12 hp gale 1956
Postby FrankR » Mon Jan 15, 2018 8:14 pm
I don't think the Gale fuel pump conversion allowed you to use your choice of tanks. Unlike the 3hp Johnson and Evinrude conversions with extra fuel line valves.
Re: 12 hp gale 1956
Postby FrankR » Mon Jan 15, 2018 8:22 pm
Gale accessories book doesn't show any carb parts with the fuel pump & tank kit
Adam1961
Re: 12 hp gale 1956
Postby Adam1961 » Mon Jan 15, 2018 9:33 pm
Interesting. I never new that it eliminated the ability to use the integral tank.
Is that from a 1957 or earler accessory parts list? It show the nipples on the pump as being two different sizes. The 1957 motor had a large nipple in the bowl on the carb and the 1959 with factory pump had a small inlet nipple.
In any case, I think we have solved this and it is an import subtlety, that may be often overlooked, when scavenging parts and then trying to diagnose running issues.
Users browsing this forum: Analogman, Bsplit, kirkp, XR55 and 8 guests
