1928 Johnson "race" motor
Adam1961
Re: 1928 Johnson "race" motor
Postby Adam1961 » Fri Jan 19, 2018 8:37 am
The R designation on the model numbers began in 1928 with the introduction of the 40 series engines. In 1928, the racing engines did not have significant external differences from the service models (ex P40 vs PR40). The changes on the racing models for 1928 included bearings in place of bushings on some late production motors and other internal changes.
The racers changed significantly in 1929 when the 45 series was introduced. The mid sections got shorter, the gear case was more streamlined, carbs had velocity stacks rather than shielded intakes and the exhaust was above water. The 1929-32 models were similar. There were more refinements after 1933 when the 65 series was introduced.
Although the 1928, 40 series motors are not what most people would think of as a racer, they are part of the evolution of boat racing and are an important part of my collection when it comes to showing the evolution of Johnson motors.
kirkp
Postby kirkp » Fri Jan 19, 2018 2:35 pm
Finally heard back from my friend who's talking to a guy who's friends of the guy with the motor. Very frustrating!!! Turns out it's a KR-40. Trying to cut out all the middlemen so I can take a look at it. Still no more pictures. Hopefully more to come.
Kirk
Adam1961
Postby Adam1961 » Fri Jan 19, 2018 2:55 pm
The KR-40 is still a neat motor. It will look just like the K-40. I thought I had found one a few years back, but the serial number on the rope plate did not match the one on the crankcase, so no way to know if it was a real KR without opening it up. As someone who is interested in Johnson motor history, I think that is a neat motor. If you are looking for speed, the KR series really took of with the introduction of the KR55 as an alternate firing twin.
spike
Postby spike » Sat Jan 20, 2018 9:40 am
Thought I would show a couple pics of my numbers matching (80750-c) 1928 KR-40.
"ANTIQUE JOHNSONS" Gotta Luv Em!
SquierKA39
Postby SquierKA39 » Sat Jan 20, 2018 10:57 am
The muffler is very different on the one in question and the numbers matching one above. Any thoughts on that? It looks bigger like the PR maybe, but sellers says it’sa KR. Interesting.
spike
Postby spike » Sat Jan 20, 2018 11:28 am
Squier, Can't say for sure about the muffler but I have heard is they used the older round can type for the early 28's and went to the new box type as used on the 1929 K-45 for the late 28's. My serial 80750 puts it in the middle of the 1928 production so who knows? Hopefully someone with more knowledge will be able to help say for sure.
Postby Mumbles » Sat Jan 20, 2018 11:45 am
I'm trying to find my Hubble catalogue to find photos of his racing KR-40's. I was sure they were alternating twins with a side exhaust similar to these KR-38 and KR-55's.
1938_Johnson_KR38 - Copy.jpg (60.39 KiB) Viewed 113 times
KR-55_Johnson - Copy.jpg (63.84 KiB) Viewed 113 times
SquierKA39
Postby SquierKA39 » Sat Jan 20, 2018 1:16 pm
Mumbles wrote:I'm trying to find my Hubble catalogue to find photos of his racing KR-40's. I was sure they were alternating twins with a side exhaust similar to these KR-38 and KR-55's.
Nope, the K40 and KR40 where opposed twins, the alternate twin did not get made until 1940 with the K50 and KR55 model.
I’ve seen a KR40 run on a small period correct hydro. Neat to see them go. Not scorchingly fast, but fun all the same.
I’m pretty sure Hubble did not make anything for the KR40, it was obsolete by then. Lots of stuff for the KR55 though.
Postby Garry in Tampa » Sat Jan 20, 2018 2:04 pm
The KR-55 powerhead was used on a water pump used by the Army & Navy services During WW2. Hundreds were available as surplus after the war. If your KR-55 has an alnico magnet magneto, it was a late model Army surplus pump, probably built by Hubble. . . 8-)
spike
Postby spike » Sat Jan 20, 2018 2:16 pm
There seems to be some confusion arising between the 1928 opposed KR and the much later alternate 1930's KR.
Users browsing this forum: Bing [Bot], Bob D and 4 guests
