Elto Rudder twin timer bushing seems sloppy to me.
Huntleybill
Postby Huntleybill » Sun Jan 21, 2018 5:24 pm
Restoring a rudder-twin and it seems to me that the bushing for the timer is awful sloppy. I have attached a video that shows what I mean. Is it supposed to be this sloppy? If not, how can I fix it?
Video: https://youtu.be/RQGLWTb9r0w
Thank you for your time
Bill
Re: Elto Rudder twin timer bushing seems sloppy to me.
Postby Dave Bernard » Sun Jan 21, 2018 6:10 pm
I have not worked on them BUT is that screw an adjustment?
Huntleybill
Postby Huntleybill » Sun Jan 21, 2018 8:35 pm
Yes, it is an adjustment. I believe that adjustment is to give it friction so the timer won't move on its own. I don't think it should take up the slop.... should it? Am I wrong? Advice?
MonteNZ
Postby MonteNZ » Mon Jan 22, 2018 2:20 am
That is the friction the adjustment screw and I would think that screwing it in would fix the problem.
If that doesn't do it, I would suggest you fit a suitable piece of shim metal as well.
Monte NZ
Tom Manley
Postby Tom Manley » Mon Jan 22, 2018 6:25 am
That's pretty loose. It'll work if you can use the tension screw to keep it in place, but it may drag on the tank.
T
Huntleybill
Postby Huntleybill » Mon Jan 22, 2018 9:58 pm
I'll see if I can find some shim material. If not I will tighten the tension screw. The motor probably won't get near enough use to matter but since it is apart, might as well fix it right.
Users browsing this forum: No registered users and 7 guests
