Home › Forum › Ask A Member › HD 25 Carb percolting › Re: HD 25 Carb percolting
August 2, 2018 at 3:10 am
#80537
I have trimmed that piece of rubber at the end that looked rough. Hope it does not have an adverse effect. I’ll find out I guess. Should the pump be a tight fit on the outer rim as well as around the cam? Or just on the cam and loose on the outer area?
