Re: 1960 15HP Gale Buccaneer Sea King
Home › Forum › Ask A Member › 1960 15HP Gale Buccaneer Sea King › Re: 1960 15HP Gale Buccaneer Sea King
My last post seems to have disappeared so I will post again.
I assume what I wrote was on a previous page that disappeared when the login screen popped up after I hit "Submit".
Anyway, Thank you FrankR and Mumbles for your response.
Hopefully I did not hurt the engine.
Thank you for the bright nail polish idea. I will use it.
I was unable to see the grommet and water tube line up because when they match up it is too far up into the cavity. I will paint the end of the water pump grommet with water based paint from my grand kids paint kit next time I disassemble which I suspect will be right after the lake checkout.
My kids gave me a LED headlamp for my birthday that is as bright as the old slide projector lamps. That should tell you something about when I was born.
Next stop is the lake.
Thank you again.
@Hans. I wish I could attend but live way down south. I was born in Grant back when the assisted living place in Grant was a hospital. Fond memories of the spring summer and fall and the lake.
