Seals- Low Cost, or just "Cheap"?
Postby Buccaneer » Tue Feb 06, 2018 8:59 am
Anyone ever try these seals from the Czech Republic?
https://www.ebay.com/itm/322597943990
I know that "you get what you pay for", but
at $1.85 ea. with free shipping, they're tempting for those motors that
I'll run once and throw on the rack!
The metric seal noted appears to be a good replacement
for the 1/2" shaft x 1" OD seals.
Re: Seals- Low Cost, or just "Cheap"?
Postby Dave Bernard » Tue Feb 06, 2018 9:48 am
are they ethanol resistant ???????????????????
Dan in TN
Postby Dan in TN » Tue Feb 06, 2018 10:13 am
Viton is the best affordable material that is ethanol resistant. They list a Viton seal. The preferred color is brown which they show. OMC used Viton seals & gaskets in brown color to signify Viton. It is normally expensive vs regular (buna N) material.
There are a lot of thing that go into a quality seal, but for this cheap price might be worth a try. I would not put them in the gearcase as there is no mention of the case being stainless steel. Chris P. has tried that & found they don't last. JMHO
Dan in TN
Postby Mumbles » Tue Feb 06, 2018 11:37 am
I'm showing them as NBR, or nitrile-butadiene rubber. :?
Dan in TN
Postby Dan in TN » Tue Feb 06, 2018 12:02 pm
I didn't click on the order button, but did look at all the pictures. They show different seals, colors, etc. I thought they offered different styles, materials, etc. If they don't offers Viton material then I'm out! Of course I would expect the price to reflect the Viton cost.
Dan in TN
Seakaye12
Postby Seakaye12 » Mon Feb 12, 2018 1:15 pm
I e-mailed them and asked if they had the seal that you initially referenced in Viton. It took them a few days but they replied that; yes they do....and it is E-bay ID # 322597943990
Viton is listed as VIAS = FKM
BR
https://www.ebay.com/itm/pack-Rotary-sh ... 8Es9FPIB2Q
Users browsing this forum: bobw and 5 guests
