OA-60 Johnson grey paint
twostroke
Postby twostroke » Tue Feb 06, 2018 12:06 pm
Does anyone have a formula # or any other info on the correct grey for an early '30's Johnson OA-60? I have one that may be my next victim.
Thanks!
Jim
Re: OA-60 Johnson grey paint
Postby Richard A. White » Tue Feb 06, 2018 1:03 pm
Machinery grey????
SquierKA39
Postby SquierKA39 » Wed Feb 07, 2018 10:48 am
I think everything was dull aluminum on the Johnson of the 30’s. What part do you think is grey?
twostroke
Postby twostroke » Wed Feb 07, 2018 11:13 am
On mine....both cylinders are a solid grey a little bit lighter, possibly, than a Square D breaker box. The foor of the lower unit shows vestiges of the same grey (I think...) and it's all rough cast.....no signs whatsoever of polishing. The flywheel shows traces of the same color on the top surface, and the sides (vertical part) is all grey. I'm trying to find out what this 'really' looked like in 1932 when it was new. That's what I want to replicate.
I can post pics tonight if that would help.
Any/all input GREATLY appreciated!
Thanks!
Jim
Postby Mumbles » Wed Feb 07, 2018 12:02 pm
Armor Coat Misty Grey rust paint from Canadian Tire comes to mind. I've used it on compressors, trailers, anything. It comes in quarts or gallons.
http://www.canadiantire.ca/en/pdp/armor ... 9107p.html
Misty Grey.jpg (20.95 KiB) Viewed 605 times
LeRoi Portable.JPG (2.93 MiB) Viewed 605 times
Postby Tubs » Wed Feb 07, 2018 12:13 pm
I just used some Rust-oleum on my OA-60.
twostroke
Postby twostroke » Wed Feb 07, 2018 12:26 pm
That looks about like the cylinders & flywheel on mine. Found these crummy pics on my phone...
Keep your garage locked, Tubs.....I need that carb hot air tube!
Jim
opposedtwin
Postby opposedtwin » Wed Feb 07, 2018 3:42 pm
I used light machinery grey on my oa-65. I only painted the jugs. I thought it turned out a bit too light. I'll get a pic tonight.
Postby Tubs » Wed Feb 07, 2018 6:12 pm
twostroke wrote:I need that carb hot air tube!
The reason you need one is when you
tilt the motor forward it gets crushed if
the power head it turned to the left or right.
This is the best I could do with the one
I had. Art Decalb sells cast ones so I
tried one. They are pretty crude when
you get one but clean up pretty well.
Not original but better than nothing.
Ait Tube.jpg (711.35 KiB) Viewed 560 times
SquierKA39
Postby SquierKA39 » Thu Feb 08, 2018 6:38 pm
I learned something new I guess. Now I’ve got to check out the OA motors at the next meet I go to, if any show up.
