Sportsman gear case
alanp
Sportsman gear case
Postby alanp » Wed Feb 07, 2018 9:41 am
I am hoping somebody could tell me or have a parts list.
Does a gearcase from a 1939 sportsman #4296 fit on a 1937 sportsman #4207.
Thank you. Alan
Re: Sportsman gear case
Postby Garry in Tampa » Wed Feb 07, 2018 2:35 pm
They used a piston type water pump in 1937, that was changed to a centripetal type in '38. SO - anything from '38 through '47 should work. . . :D
There was a change in the parts books also . . .
alanp
Postby alanp » Wed Feb 07, 2018 2:50 pm
Garry,
So do you think can I put a 1939 gearcase on my 1937 if the water pumps were changed.
Alan
Postby Garry in Tampa » Wed Feb 07, 2018 4:47 pm
Easier to put the '37 powerhead on the 39 driveshaft housing and change the model number tag. Many differences were made. Different exhaust pipe length, different drive shaft , etc.. Anyone would (should) know it would be worth less money than an original '37. For general motor use, it would be more dependable. The piston pump wore rapidly running in silty conditions. The later models are much preferred for digging channels through sand bars . . . :lol:
alanp
Postby alanp » Wed Feb 07, 2018 5:42 pm
Thanks for all the information. I have a ‘37 with the scag broken off. I will just keep looking for the correct gearcase.
Alan
labrador guy
Postby labrador guy » Sat Feb 10, 2018 10:57 am
Alan, my propeller guy fixes scags all the time. Last one he fixed for me, I made a pattern from another motor out of cardboard. Came out real good. Some people are masters with those helearc welders! Jim's Prop Shop Standish MI.
dale
