impellers-18-3001 vs 18-3002
bookfuzz
Postby bookfuzz » Fri Feb 09, 2018 12:23 pm
Can anybody tell me the difference between the two impellers.
I can't see one based on a side by side comparison.
the 3001 is for OMCs 3 to 7.5 hp and the 3002 is for larger ones.
tkwalker
Re: impellers-18-3001 vs 18-3002
Postby tkwalker » Fri Feb 09, 2018 12:34 pm
If I remember correctly the difference is the Drive shaft bore size ... I stock all of these in BRP, I'll check this out.
Postby FrankR » Fri Feb 09, 2018 12:53 pm
tkwalker wrote:If I remember correctly the difference is the Drive shaft bore size ... I stock all of these in BRP, I'll check this out.
Exactly. That is the only difference.
mercuryman
Postby mercuryman » Fri Feb 09, 2018 1:22 pm
18 3001 shaft .430
18 3002 shaft .501
Mercury -MK25, MK10, KH7, KG7,KG4, KE4,KE4, KF5,KF3,KE3
Wizard WH7
Sea King 5
Bendix SMD , Champion Hydro-Drive 4.2 , Scott 7.5
bookfuzz
Postby bookfuzz » Sun Feb 11, 2018 5:58 am
Thanks. I figured it was something like that.
Where did you find those numbers? Or did you measure them.
mercuryman
Postby mercuryman » Sun Feb 11, 2018 9:14 am
I have a Sierra part # to size info sheet. Copied it off our WEB SITE WAY BACK.
Wizard WH7
Sea King 5
cron
