Well, this wasn't supposed to happen...
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Sat Feb 10, 2018 5:02 pm
Long story short, I had to disconnect the fuel line from the carb. Instead of the hose pulling off of the barb, the barb pulled out of the carb.
What is supposed to hold the barb in? It almost looks like it was soldered.....but you can't solder to an aluminum casting.
Is the "factory insertion" supposed to be permanent? Stated differently: am I screwed?
Re: Well, this wasn't supposed to happen...
Postby Jerry Ahrens » Sat Feb 10, 2018 5:24 pm
i don't think I've ever had that happen on one of those carbs.. is that lead on the end? You may be able to simply tap it back in.
If nothing else, a little Marine Tex Epoxy on the outside will do the job. It works on my old Ford tractor anyway.
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Sat Feb 10, 2018 5:28 pm
It does look like lead.....as if it had been soldered in.
I don't have any Marine Tex....but I do have JB Weld. I suspect that would work just as well. It claims to be gasoline proof once cured.
Postby FrankR » Sat Feb 10, 2018 5:53 pm
Locktite threadlocker
Chinewalker
Postby Chinewalker » Sun Feb 11, 2018 5:58 am
Or try red Locktite. Good with metal on metal.
aquasonic
Postby aquasonic » Sun Feb 11, 2018 6:57 am
I'll take a drop or two of locktite any day over mixing up messy epoxy.
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Sun Feb 11, 2018 8:08 am
Why? Ease of use or better capability of the Loctite product?
(I used JB Weld last night...)
SquierKA39
Postby SquierKA39 » Sun Feb 11, 2018 9:57 am
I think you’ll be fine with the JB weld. It won’t come apart now and if you got it all around it shouldn’t leak. I probably would have used the same thing.
Bob D
Postby Bob D » Sun Feb 11, 2018 11:05 am
I haven't had good results with JB Weld and gas. Tried to put the drain screen on the pickup tube back on a fifties OMC tank and it did not hold. Cleaned it well before application with a wire wheel, and brake cleaner.
Just my experience.
Bob D
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Sun Feb 11, 2018 1:03 pm
So how are these fuel barbs supposed to be held in place?
Users browsing this forum: auldscott, Google [Bot], JoeCB, Mike Stroz, NJ-boatbuilder57, Wagemaker and 13 guests
