oil
chuck86
oil
Postby chuck86 » Tue Feb 13, 2018 8:25 am
what oil and weight do you recommend for my 1920 motors
would like to use one oil
is 8 oz per gal ok?
Chinewalker
Re: oil
Postby Chinewalker » Tue Feb 13, 2018 9:40 am
Use the modern TCW3 rated oil of your choice/preference. Any modern oil with that rating will be much, much better for the motor than anything available way back when.
Most folks I know running 1920s iron use 8:1 ratio, or in that ballpark. It's what I run in my '28 Quad and Speedsters.
outbdnut2
Re: oil
Postby outbdnut2 » Tue Feb 13, 2018 9:48 am
chuck86 wrote: is 8 oz per gal ok?
Use 16 oz/gallon, That is 8 to 1. Amazing how they hardly smoke at all when they get warmed up and running on this much oil.
Re: oil
Postby Mumbles » Tue Feb 13, 2018 10:57 am
For Johnson owners:
Old Johnson Oil Ratios.JPG (82.55 KiB) Viewed 378 times
twostroke
Re: oil
Postby twostroke » Tue Feb 13, 2018 12:06 pm
Saved and printed. Thanks!
Jim
I say "Pardon Me" a lot. I had a 20H with a toilet bowl, then raced open mod sleds. :D
Garry in Tampa
Re: oil
Postby Garry in Tampa » Tue Feb 13, 2018 2:31 pm
The problem with some antiques is that the production specs of that era were of greater latitude than the precision machines of today produce.. No seals were used and many depended or grease or heavy oil to seal the crank case. (Many Row Boat Motors have grease cups on the crankshaft bearings) Todays oils are fantastic as far as eliminating ware but some antiques may require a shot of heavy weight oil to properly seal the motor. Unfortunately this promotes carbon formation, requiring periodic service to remove. If ignored, carbon flaking off the combustion chamber con score cylinder walls. At none time this was thought to be caused by a lack of lubrication which made them recommend more oil . . . :lol:
Last edited by Garry in Tampa on Tue Feb 13, 2018 6:19 pm, edited 1 time in total.
chuck86
Re: oil
Postby chuck86 » Tue Feb 13, 2018 3:39 pm
Garry in Tampa wrote:The problem with some antiques is that the production specs of that era were greater latitude than the precision machines of today produce.. No seals were used and many depended or grease or heavy oil to seal the crank case. (Many Row Boat Motors have grease cups on the crankshaft bearings) Todays oils are fantastic as far as eliminating ware but some antiques may require a shot of heavy weight oil to properly seal the motor. Unfortunately this promotes carbon formation, requiring periodic service to remove. If ignored, carbon flaking off the combustion chamber con score cylinder walls. At none time this was thought to be caused by a lack of lubrication which made them recommend more oil . . . :lol:
chuck86
Re: oil
Postby chuck86 » Tue Feb 13, 2018 3:54 pm
[img]http
s://www.walagata.com/w/chapsboy/0-Signature.jpg[/img]
My understanding is TC-W3 is oil that has passed certain standards. I have thought of using Tohatsu 2 stroke outboard oil.
Can I add one or two ounces of 40 wgt non detergent oil or will this give me problems .. Otherwise can just use 40wgt non detergent. Only plan on running this a 3 or 4 times this summer. Same applies to my other 4 1920 motors.
Thanks for your Input
chuck86 So far 154in of snow - more on the way.
Garry in Tampa
Re: oil
Postby Garry in Tampa » Tue Feb 13, 2018 6:27 pm
Adding a little SAE 40 wt non-detergent helps. That is what I do on my well used antiques. Steve Woods does not, but his antiques are rebuilt to very exacting specifications. . . ;)
Chris_P
Re: oil
Postby Chris_P » Tue Feb 13, 2018 7:26 pm
Be aware of WHICH motor you are running as well. Racing motors for one obviously require more oil than trolling motors do.
Users browsing this forum: auldscott, Google [Bot], JoeCB, lindy46, Mike Stroz, NJ-boatbuilder57, Wagemaker and 14 guests
