1990 25 hp Johnson J25RESB neutral safety switch is acting up
outboardnut
Re: 1990 25 hp Johnson J25RESB neutral safety switch is acting up
Postby outboardnut » Mon Mar 12, 2018 3:15 pm
It must have been converted
reduce reuse recycle
Jerry Ahrens
Postby Jerry Ahrens » Mon Mar 12, 2018 6:30 pm
I'll bet Dan's right, you probably have some wear on the plastic parts too. My motor that I mentioned earlier has a little different set up, but uses the same switch. You should never bypass a neutral safety switch... just for testing purposes sure, but it needs to be fixed right.
Jerry Ahrens AOMCI Member MAPS Chapter President
outboardfix
Postby outboardfix » Mon Mar 12, 2018 7:53 pm
If the motor has a electric start type remote control that had a key switch, you may find the same switch inside that isn't being used, no need to have two.
outboardnut
Postby outboardnut » Mon Mar 12, 2018 9:07 pm
It is a tiller
Users browsing this forum: Bsplit, jnjvan and 6 guests
