1925 Johnson A-25
John C
1925 Johnson A-25
Postby John C » Sun Mar 11, 2018 10:37 pm
The weather here was good today so ran some motors. This Johnson A-25 started right up after sitting for several years. Noticed the prop and nut missing after removing motor from test barrel. The prop shaft isn't drilled for a cotter key to hold the prop nut in place. How do I keep from losing that nut when I run the motor?
Re: 1925 Johnson A-25
Postby Mumbles » Mon Mar 12, 2018 1:51 am
The operators manual says there should be two nuts, a flat one and a locking acorn nut.
J A.JPG (88.37 KiB) Viewed 200 times
John C
Postby John C » Mon Mar 12, 2018 3:13 am
Thanks Mumbles. That makes sense.
Users browsing this forum: jnjvan and 6 guests
