Prop pitch question
Re: Prop pitch question
Postby FrankR » Mon Mar 26, 2018 4:56 pm
Or an optical tach (requires running with hood off for test)
https://www.amazon.com/AGPtek%C2%AE-Pro ... tachometer
Postby fleetwin » Mon Mar 26, 2018 5:14 pm
NJ-boatbuilder57 wrote:Thanks, guys! Good info all around.
Pardon my ignorance, but it sounds like a tach is pretty important to getting everything dialed in. But as far as I know, my engine has no provisions for a tach. What's a fellow to do?
Absolutely correct on both counts. So, you will need some sort of shop tach. The problem is finding one compatible with a two stroke and making sure it is set up properly...Inaccurate tachometer readings just waste your time and cause even more confusion...
Postby outbdnut2 » Mon Mar 26, 2018 5:38 pm
The Tiny Tach has a wire that you wrap around the outside of one spark plug wire to sense RPM. There are others out there that have a sensor that clips around the outside of a spark plug wire - all are easy to use. A tach is the best way, but I don't generally use one - I've gotten a bit of a "feel" for proper performance and engine sound. You can buy a TinyTach online at E-BAy , Amazon, and other places. for $45 to $50. They are also good for setting idle RPM, and can be used on virtually any gasoline engine. You just have to, as was said in the previous post, set a tach up for 2 or 4 stroke and the number of cylinders to get a correct reading.
gdcarpenter
Postby gdcarpenter » Mon Mar 26, 2018 8:34 pm
Hi, looks like a GlenL 'ZIP'. My GlenL 'ZIP' runs 29-30 MPH @ 5,600 RPM with a 1959 35 HP outboard.
(In terms of full disclosure it's a Mercury Mark35A)
My best results have come from a 10" diameter 10" pitch prop giving me the above top end results, using a tach for RPM and a GPS for speed. A 12" diameter 11" pitch prop was too much prop for my boat, which weighs in a little under 800 lb. fully load for a days outing with 6 gal. of gas.
A tach is rally important to dial in your prop, so at WOT you are at or near max. RPM.
Postby FrankR » Mon Mar 26, 2018 9:29 pm
gd, by any chance are we comparing apples with oranges now? How do the gear ratios compare between the Merc and OMC? And was your Merc a two-blade?
NJ-boatbuilder57
Postby NJ-boatbuilder57 » Tue Mar 27, 2018 7:07 am
Hi gdcarpenter: it's a ski-tow, and I'm on that 'other' forum, too. I posted pages & pages of build photos....until photobucket sank.
I guess the mission is to dial it in with as many props as are needed to find the sweet spot. That could get expensive! :)
Tachs: are the $10 "ebay tachs" as good as the $50 tiny-tach? They all look to be just about the same....
Postby Dave Bernard » Tue Mar 27, 2018 10:39 am
I may have a merc-o-tronic shop tach for testing it hooks around the spark plug wire. works on any motor that has plug wires.
gdcarpenter
Postby gdcarpenter » Wed Mar 28, 2018 7:22 am
The Merc is Pinion 14 : 23 Propeller for the gear ratio.
The 10" diameter 10" pitch prop is a three blade brass prop.
The 12" diameter 11" pitch prop was a two blade aluminum prop.
wbeaton
Postby wbeaton » Wed Mar 28, 2018 10:54 pm
FrankR wrote:gd, by any chance are we comparing apples with oranges now? How do the gear ratios compare between the Merc and OMC? And was your Merc a two-blade?
It is apples to oranges. From my experience, if a 40 ci Mercury runs best with a 10P prop then a 35 hp Big Twin/RD will likely need a 13P prop on the same boat. That is anecdotal based on motor/prop testing on Feather Crafts, which is also an apples to oranges comparison. :)
Also, I have used an automotive timing light with a built in tach when prop testing. It’s one of three tachs I use.
OLCAH
Postby OLCAH » Sat Mar 31, 2018 4:43 pm
Brings us back to NJ-Boatbuilder57's question:
"Tachs: are the $10 "ebay tachs" as good as the $50 tiny-tach? They all look to be just about the same...."
Does anyone have experience with both?
Users browsing this forum: Bullie, Lloyd Lautner, Mr. Asa, reivertom and 18 guests
