Re: Row Boat Motor Tank Repair
Home Forum Ask A Member Row Boat Motor Tank Repair Re: Row Boat Motor Tank Repair
Topics: 1074
#84234
quote Richard A. White:
If memory serves, you don’t even need to seal the pin holes… use tape over the holes on the outside and the coating fills the holes… I believe that is written on the outside of the can with the instructions…. a little does go along ways..
Richard, I wanted to seal the pin holes so the phosphoric acid would stay in the
tank long enough to clean the insides out! Only the little filler cap in the
corner to look into the tank, so no good way to inspect the sides of the
tank as a whole. I like the "idea" of un-soldering the top of the tank, but
not the potential for screwing it up!
